Does anyone happen to know what the component that I circled here. It is a simple thing that I need to buy to go around a 7/8 inch OD copper pipe.
Also - where would I go to get one?
  • 4
    that looks like it is custom made for the device in the picture ..... what problem are you trying to solve? – jsotola Jan 27 at 20:29
It's called a Square O Strap. The one in your picture is already "set" in place so ones bought separately will need to be soldered to the pipe.
Example
That looks like a wall plate that can be screwed in place to help hold the pipe. Sometimes those are used when pipes will have a lot of movement like a water spigot. From the looks of the fitting you have there, this pipe will not be moved around very much after installation is complete. If the piping is strong, just go back with an escutcheon. AKA remodelers plate or smitty plate. They come in many designs and are available at any plumbing or building supply store.
7/8 Escutcheon
