I'm considering installing an electric tankless water heater in my house, but need to know what amp service I currently have. I read that you should look at the amps on the main breaker to the house to determine this. So I inspected the main panel on the outside of my house, and found the main breaker that feeds to the subpanel inside the house. It is a 2-pole breaker that says "100" on each side. Does that mean it's 100 amps total or 1100 on each pole (=200 amps?):
And here is the breaker with the panel face off:
And the main panel itself is wired up from the meter via these two wire:
Another pic of the main panel's center portion:
