I got a shop-light fixture, leftover from a construction site. The metal boxes with 4 foot tubes. It has wiring for two lights in it - two of the small rectangular connectors on each end that you twist the tube into. This light is big enough for 4 tubes - it's 4' by 2', and I've seen them that size with four bulbs in the store. It has a black ballast box in the middle that shows how to wire it for two lamps.
So I also acquired another ballast wiring harness that shows wiring for three bulbs. Couldn't I install the three-lamp ballast box next to the two lamp one, put in the connectors and only use two of the three extra spaces? Basically turn the 2 bulb fixture into a 4 bulb fixture? The wiring shows that the three-lamp ballast will provide power "up to" three bulbs, but there's nothing saying I can't install just two of the bulbs and leave the third empty.
Would there be excessive heat build up from two ballast boxes being in there?
    Since you're modifying it anyway, have you considered LED conversion? There are tubes that take line voltage, eliminating the ballast entirely.
    – Tim B
    Oct 12, 2017 at 15:24
  • FYI a three lamp electronic ballast can be used to light 1 - 3 lamps. We call them smart ballasts. More FYI you can also purchase LED's that snap right into and replace the fluorescent lamp without removing the ballast. They used to be about $17 ea. contractor price, about the same price I paid for a ballast. I have no idea what retail is. Oct 13, 2017 at 12:59
  • Ledmyplace has direct wire/ ballast compatable lamps for under 10$ I use the 3000 lumen 20watt model much brighter than a standard t8. I think I have installed about 30 of these so far double ended is my preference hot at 1 end neutral at the other, the ones I have will work with a ballast also but I want to reduce failures so I take them out.
    Jan 3, 2018 at 0:29
If there's a mounting location for a second ballast, yes. Many 4-lamp fixtures do provide for 2 ballasts, and are built for same.
Try to use modern electronic ballasts. They are plentiful dirt cheap on eBay and Craigslist now that so many people are doing LED conversion.
I would add to this, some electronic ballasts are actually made to drive 4 lamps. The wiring can get a little bit knotty and you have to watch your wiring diagrams.
