The short question is this: would a low-flow shower head cause some kind of increase in pressure to the water supply pipes that would cause a rupture and leak?
The longer story is this: I removed a previous stationary shower head and replaced it with this hand-held shower head (http://www.homedepot.com/p/MOEN-Propel-5-Spray-4-5-in-Hand-Shower-in-Chrome-26040/300676251). There was nothing unusual about the installation, it worked fine and there were no visible leaks.
About two weeks of daily use later the hot water to that bathtub faucet and only that bathtub faucet stopped working. A plumber came out and replaced the cartridge inside the handle (http://www.homedepot.com/p/MOEN-Posi-Temp-Pressure-Balanced-Shower-Cartridge-1222/202059049) saying that sometimes the temperature regulator inside the cartridge stops working, just one of those things.
Hot water had returned, we went back to daily use. About 4 days later we heard water behind the wall and found our downstairs bathroom below the shower in question was flooding from the ceiling. We turned off the main water and waited for the plumber to come back out.
He found that the cold water supply line to the shower handle was leaking significantly at a solder point. His initial diagnosis was whoever installed the line had done a bad job soldering the pipe and it had finally given out. He cut out the pipe and replaced it with his own, presumably superior, soldering job.
After he was done, as he was using the shower head to clean out the tub he mentioned how much he hated these kinds of shower heads because they restrict the flow of water so much, and that since "that pressure has to go somewhere" the new shower head was likely the cause of both the cartridge replacement issue and the later leak.
I would agree the shower head does not put out the most impressive pressure, but it doesn't seem anemic or problematic. I can't understand how a restrictive shower head could ruin a scald protector or supply line. Is this actually a thing? Should I look to replace my shower head, or was he just looking for something to be the cause that wasn't him? If not the shower head, could the cartridge be doing something that would cause the pipe to leak?
  • 10
    You have a sealed plumbing system under a certain amount of pressure. If you tap into it for a shower head, that releases some of the pressure on that branch of the system when the shower head is in use. The plumbing has to be able to take the normal pressure and not leak when the shower head is not in use. No matter how restrictive the shower head is, it is still less back pressure than when it is not in use. The shower head has no relationship to your plumbing leak or cartridge failure.
    – fixer1234
    Jul 24, 2017 at 1:16
  • Well, the pipe between the shower tap and the shower head would be unpressurized when the shower is not in use, so changing the head could plausibly cause that pipe to leak, but not this one.
    – user253751
    Jul 24, 2017 at 2:33
    @immibis, correct, but it still has to meet the same standards and not leak. If it leaks, it's a defect in that pipe, not a problem with the shower head.
    – fixer1234
    Jul 24, 2017 at 2:35
This is a fun question. I feel your plight and frustration. The answer is multi-point.
The TLDR version: Yes, a restrictive component upstream from your faucet control and the spicket can introduce the conditions needed for a leak between those two points.
When the faucet itself was off however, all of the water pressure in the home in the pipe is pushing on all sides of the pipe's and faucet's inner surfaces. Home water pressures can be about 60 psi (different codes in different places), but this PSI is regulated by a regulator on your main water supply. All the water in your home is restricted to whatever this is set at.
Now, when you open a faucet, you are giving that water a place to go. Think path of least resistance. The water goes there, but unless the pipes it is going through are too small (like a refrigerator water line) that water will come out at 60psi.
Suffice it to say for the example, the pipe between your shower handle and the shower head can handle say 40psi…. when you open the faucet, with no head, all 40 psi (nearly all), blasts out into the tub. Now put your thumb on it, and some MORE pressure pushes on the pipe sidewalls, while less than 40 comes out. Now put a low flow head on it, and even less.
So yes — if a pipe was weak to begin with, it can start leaking. Now, as far as the cold supply leaking because of the new head? BALONEY. Because when the water is OFF, it is seeing all of the pressure at those connections.
What is most likely the issue with the leak and the faulty faucet (I assert…) is that the act of you touching the shower head pipe had more vibrational impact on the overall piping installation. Also, calcium or other water impurities built up in the pipes may have broken free. This could be what caused the water mixer to "seize up" and also could be what weakened the pipes more than they were before you started the task.
How old is the house? These things do happen. Also, the plumber (while not at any fault), also jostled these connections, and he is right, if the job was lacking in quality, then everything you experienced could happen.
  • Its a condo unit, the building was built in 2001. To my knowledge, this would be the original plumbing. The work jostling loose some waiting problem makes sense to me.
    – kscott
    Jul 24, 2017 at 2:12
I think it's much more likely you leak was due to a combination of a poor joint plus the actions of the plumber. When you work on pipes you put force on the joints. If there was one that was already marginal it might fail. This is not wrongdoing on the plumber's part, force is inevitable. You rarely have anything you can grip (with a wrench—holding it by hand isn't enough to matter) to avoid putting the force on the pipe and its joints.
Yes, low-flow shower head can cause a leak or rupture. If you’re experiencing fluctuations in shower water pressure, don’t brush the issue off. The problem could be more severe than you imagine (as it is with leaking or cracked water pipes), and possibly require professional intervention before snowballing into a home plumbing disaster.
  • Mind expanding on how a low-flow showerhead would cause a leak behind the wall? Nov 20, 2017 at 12:39
