About a week ago the worn out old ballcock system broke on the toilet. My landlord picked up the LASCO 04-4059 kit: enter image description here I went ahead and did the install as part of our rent-deal and the toilet now functions as it should but... runs constantly, specifically making a hissing gargling noise which it never did before. From what I can tell I followed the (terribly written) directions perfectly.
Today with some Googling I got pretty certain that the issue was that the new flapper wasn't forming a perfect seal. Cleaning the rim of where the new flapper sat made no difference, so I tested the seal with a piece of flat styrofoam and that seems to make a perfect seal.
Nonetheless the toilet still runs even with the seal and I do notice a slight bead of water sometimes along the side of the pump though that might be just a very occasional drip.
So I'm not sure if it's an issue with the pump or the float. Strangely if I tap the float or put my hand in the water and change the level the gargling stops for a little while. Adjusting the float level does control the water height but makes no difference with the noise.
Also I ran a test to see if I turned the water off at the valve at bedtime with the tank full whether it would be full in the morning. Strangely it was near empty in the morning which initially convinced me it was the flapper but now I'm not so sure. There was no standing puddle around the toilet in the morning either.
When I re-hooked the supply line I reassembled it as it had been prior and from what I can tell there's no evidence of a leak... no water on the floor around the line etc.
Assembling the supply line connection as previosly installed I did end up with these extra parts from the kit which are not mentioned anywhere in the directions.
As there's no evidence of a leak I don't know if they're extras or the source of the issue.
Frustrated too because as of this post I'm now at 2:30 on the 1-hour at $30/hour install deal with the landlord.
Any help appreciated. Thanks.
runs constantly
Generally when someone says it "runs constantly" it means they are talking about the ballcock valve (the fill valve). A new fill valve that constantly runs usually means that the installer did not flush the internal components of the fill valve after installation. Oftentimes debris is dislodged from the supply system (supply line, stop valve, supply pipes) that can affect operation of the new fill valve. It is standard practice for a plumber to open the top of the fill valve assembly and open the stop valve a bit, flushing the new valve diaphragm and washers. In fact I will bet $$ that the installation instructions recommend this.
However, a clue in your post makes me suspicious:
A leaky fill valve would just run all the time, but the tank would not empty. Now we need to suspect the flush valve assembly (which includes the flapper). You tested the flush valve seat surface with a piece of styrofoam and it did not leak, so the flush valve seal is OK.
So on to the flapper. Generally a bad flapper causes a slow leak into the bowl, resulting in the fill valve running intermittently, to refill the tank as the leaky flapper allows the tank level to slowly drop. The "constant" run you describe would only occur if the flapper was leaking catastrophically (using "catastrophically" in a relative fashion). I suggest you put a few drops of food coloring in the tank, this will immediately tell you whether or not the flapper is leaking (cuz you will see the dye in the bowl).
    An additional but less common issue is siphoning. This occurs when the tube from the ballcock valve that sprays into the overflow pipe (the "bowl fill tube") is inserted into the overflow such that the end of the hose is below the tank water level. this can cause constant fill valve run. Most fill valves come with a clip to prevent one from jamming the hose down the overflow. Commented Jul 10, 2017 at 2:36
Yep, my new Magma toilet repair kit constantly ran as well. Troubleshot it to a leaky tank flapper valve. Got a new soft rubbery one and that seals the tank so it doesn’t constantly empty water into the bowl.
