I see dust under the baseboard but not much. And also, sometime I can smell "crawlspace" like smell but I am not very sure.
How to technically test the air pressure in home? Even more, how to technically test the air flow in home?
  • Do you have forced air heating or cooling? If you don't,there cannot possibly be a pressure differential in your house. Commented Mar 13, 2017 at 19:36
  • I don't have forced air heating. But I am guessing leaking duct could cause negative pressure. And I'd like to understand when range hood, bathroom exhaust fan are running, what will the air flow be like. I didn't see any fresh air intake vent yet...
    – XWLI
    Commented Mar 13, 2017 at 23:53
In short, you want to use or rent a manometer.
I suggest reading this article ( http://contractingbusiness.com/archive/how-measure-building-pressures ) as it details the differences in levels room to room and what the ideal pressure should be in vented and non vented areas, ie kitchen/bathroom as opposed to bed/living room.
As for the dust under the baseboards, that can be due to improper cleaing during construction of the dwelling.
