My 20 year old State brand 80 gallon electric water heater is going bad finally. I went to the big box store and found they no longer carry a 80 gallon standard type water heater. The plumbing supply house said they are no longer making old style heater over 55 gallon, something about government pushing for more energy efficient ways to heat water.
What happened to them?
  • They didn't go anywhere; they're just three thousand dollars. google.com/…
    – Mazura
    Commented Dec 14, 2022 at 11:40
That is correct. A new Federal law, called NAECA, requires water heaters be efficient. Heaters under 55 gallons must be 95% efficient (minus a tiny margin per-gallon). Heaters over 55 gallons must be - are you sitting down? 200% efficient (minus the same margin per size). This is only possible with heat pump technology.
Imagine: taking a window air conditioner and immersing the condenser (the hot outside part) inside the water heater. The output is chilled air. This is bad news in winter since your furnace must now work harder; but in warm weather it helps cool your house.
So you can still use a large tanked heater, but you will have to go with the more exotic technology.
More on the law here.
Really, in this day and age, if you're worried about having 80 gallons of hot water, just go tankless on-demand and have infinity gallons. Assuming you have the gas vent or electrical service, of course. There are some teething pains to this technology, particularly, you need to manage demand so you don't overwhelm the heater. But once you have it dialed in, showers are awesome, let me tell you!
13
    Black Market for standard technology big water heaters? I remember people hoarding 3 gpf toilets back in the day
    – Kris
    Commented Dec 11, 2016 at 2:48
  • Uninsulated 55 gallon drum (or a tank over 935 gallons) with an electric heating element would meet the energy factor requirement of the 2015 NAECA. The energy star program has a standard for the yearly energy usage that had recently increased the insulation required to meet the standard for water heaters. This is what had caused them to make even the smaller models larger.
    – Dan D.
    Commented Dec 11, 2016 at 5:21
  • Is it legal to run two or more 50 gallon heaters hooked up in parallel? Legislators may have missed that. Commented Oct 2, 2019 at 1:57
    @WayfaringStranger I would put them in different parts of the house, since most people's bathrooms and kitchens are quite far from each other. Then you get BoBW, 10 second hot water in both locations instead of only one. That would definitely be legal. Commented Oct 2, 2019 at 2:46
    @Ron yes. Yes it does. It's like it's pulling heat out of thin air... Commented Oct 2, 2019 at 18:14
9
What you heard at the plumbing supply house is correct -- single conventional electric water heaters are no longer being made in sizes larger than 55 gallons for energy-efficiency reasons. However, you do have options here.
Shrink the tank, boost the first hour recovery
One option would be to look for a tank in the 50-55 gallon class that has very high first hour recovery capability (equal to or better than the first hour recovery of your current heater). This would probably pull more peak power than your existing State, but could easily match or beat it for total energy consumption by way of being better insulated than the old heater. However, finding high first hour recovery electric water heaters may be difficult unless you look at commercial units, and your circuit may not be large enough for this.
Go with a heat pump water heater
Over-55-gallon electric tanks are being replaced with clever little devices called heat pump water heaters. As their name implies, most of them use an air-to-water heat pump to heat the water using heat from their surroundings (this is called a unitary configuration), instead of an electric heating element. This is your best option provided you have a waste heat source in the room; otherwise, the heat pump water heater may drive your heat bill up/struggle to produce hot water during the heating season. Some heat pump water heaters are known as "hybrid" heaters and have electric elements that supplement the heat pump in high demand situations.
If a unitary HPWH is unsuitable, even with outside air ducted in for supply and return, one other option that can be explored in this space is what is called a split system heat-pump water heater. Instead of having a small heat pump atop the tank that draws heat from ambient air in the space the unit is installed in, these units use a mini-split-ish outdoor unit that heats water in much the same fashion as a tankless heater, then pumps it into a tank for storage, with cold water being drawn off the bottom of the tank for reheating. While expensive to buy and install, they provide excellent first hour recovery performance for their tank sizes, while both being highly efficient and capable of operation in a wide variety of climates.
Use two smaller heaters
You can connect two smaller tank-type heaters in series or parallel (either works, although both configurations have advantages and disadvantages) to meet your hot water needs. This allows you to use standard tanks to fit the bill, but requires two circuits. You can also use a tankless heater as a booster feeding a tank-type heater, but electric tankless heaters have extremely high instantaneous power needs, so it's generally better to use two tank-type heaters instead unless you are dealing with extreme hot water loads that exceed the first hour recovery capability of any other configuration.
Going tankless
A fully tankless setup can be used as well; however, electric tankless heaters are monsters when it comes to peak power consumption, pulling over 100A compared to the 30A draw of a standard-issue residental tank. As a result, electric tankless heaters are probably not the best choice unless you have a large electric service (upwards of 200A) and are not going to get dinged by your utility with peak charges, either.
  • Dual tanks in parallel right next to each other, with heating elements active only in one would thermosiphon. I wonder if this would work well enough. Commented Jan 25, 2020 at 11:39
