In the attic I have electricity running out to a junction box. The wire in the junction box connects 2 things. The first one is that it brings power down to a light switch. There's a NM cable coming back up to the attic over the the light.
However recently I added a transformer to the junction box to power up my Ring Doorbell (white to white, green to green, and black to black). I didn't notice this until today that my Ring Doorbell doesn't actually get direct power unless I flip the switch to the light.
I want to ask if I could just add another junction box next to the one I already have so that I would have a dedicated box supplying power to my transformer and doorbell.
So here's what I imagine. First the line power would come to junction box 1. In junction box 1, I would attach the transformer for the doorbell. I would also have another NM cable to bring electricity to junction 2. In junction 2, that's where I would reconnect to the NM cable that goes down to the light switch.
I don't know if this will work. Or is there another way where I can keep the first arrangement and be able to tap power directly from the junction box without the light switch controlling my transformer.
    Can you post photos of the insides of the boxes? Dec 9, 2016 at 12:44
  • Depending on your jurisdiction, junction boxes, if used as you describe, are not allowed. I had to have one removed and some moderate rewiring done before I could get HO insurance. Anyway you're not able pull a new wire from the main, to the switch, to the light, and add another outlet for the transformer?
    – tpcolson
    Jun 25, 2017 at 21:26
It sounds like you have the transformer wired on the switch loop so the switch position makes a difference. If you move the door bell to the light feeder it will work as it should. Can you add another box and provide a dedicated circuit? Yes, but this would be quite expensive and really not needed for such a small load.
