The washer on my Electrolux stacked washer and dryer stopped operating.
The drive belt was broken, so I recently replaced the broken drive belt which fixed the agitation cycle.
However when the cycle gets to the spin cycle, I can see the motor pulley spinning/turning, but the drive belt does not move. This causes a burning rubber smell (as the motor pulley spins against the non moving rubber belt) and eventually a load whinning noise.
This doesn't appear to be a new problem as the tenant was previously complaining of sporadic rubber burning smells and the same whinning noises in the past, so the it appears the spin cycle was sometimes working and sometimes not in the past.
Would this be indicative of some loose part?
Any suggestions, diagnosis or help on whether this can be a simple DIY and if it should be a service call would be greatly appreciated.
