I ordered a new hinge and brake for the fridge/freezer a friend dropped. The problem is the door hangs too low on the left side.
My thinking was that the bottom of the door got pushed out to the right because of the way the hinge warped, but looking closer it would appear the door itself is a bit dented. Should it be ok to try to hammer/bend that out, or should I be ordering more parts before taking things apart to fix?
