Whoops.
My deck caught fire and now I need to replace the burnt parts. From what I can tell, I need to pry up the deck boards to access the burnt joist. Then replace the decking that was damaged on top.
Is there a better way? From what I can tell the decking is nailed down every 16-18 inches and pulling the nails out far enough back to access the joist seems like it's going to be quite a chore.
No problem if that's the best solution, just want to be sure before I invest time and money. Also, want to prevent further damage where I can.
