I'm looking to build a pergola like this one.
Would a connector such as the concealed Simpson StrongTie CPTZ work for the posts?
The specs seem fine, what I'm worried is the footnote "Post bases do not provide adequate resistance to prevent members from rotating about the base and therefore are not recommended for non-braced, or non-top-supported installations.", though it seems this is the same for most of their connectors.
    I think they are talking about free-standing posts, like... a rural mailbox post? Should be fine for your application, plenty of other structural components to prevent rotation. Sep 25, 2016 at 3:57
  • I agree with the post mounted at the base and top I have used steel 1/8" plate in a saw cut and drilled for a non load bearing structure that I did not want external metal brackets on.
    Sep 25, 2016 at 6:37
  • Might work, but my concern would be the relatively short stalk coming up from the plate. Have you considered having something bigger fabbed at a welding shop? Sep 25, 2016 at 14:46
Hi this is Jason of Builderbeast. I built this pergola, and was also not thrilled about the size of that Simpson connector. I had a larger 1/2" stainless mount fabricated. It extended about 12" up the column.
