I had the drywallers install denshield tile backer and I am finally getting around to tiling. I noticed a problem while looking at it the other night. Most places I've seen say that the gap between the tub and the backer should be 1/4"-1/8". I'm not sure what happened here, but it looks to be about 1 1/8" to 1 1/4".
Can I still tile with this or do I have to cut out a section 1-2" above and install new denshield to the correct tub gap? I don't think the grout will stick correctly if there is a void behind it.
I will be contact the drywallers to tell them about this, however, the project was done around 2 months ago.
thanks,
Eric
