Will constantly turning the power off/on manually (one to four times a day) at the circuit breaker box cause any damage to the box itself or to the wiring in the specific room and will it most likely result with a higher utility bill?
As long as the breaker is rated as switch-duty (SWD), there should be no problem switching in ON/OFF many times.
  • I appreciate the info. What if it's not SWD? Still okay?
    – J and J
    Commented Sep 24, 2016 at 17:48
  • @JandJ if it's not switch-duty, then using like a switch will wear it out.
    – Tester101
    Commented Sep 24, 2016 at 21:01
Right. The only foreseeable problem you could ever have with this procedure would be wearing out the breaker itself over a period of time.
