As in the title, I've got a lamp hanging from the ceiling, with a regular E27-screw bulb attached. When I turn the light on, there's a quiet, buzzing noise.
The lamp was installed a couple of weeks ago and I am not sure whether the noise was there from the start, as the lamp was not used often.
While the noise is there, the light keeps still, no flickering.
I've tried 2 other bulbs and the problem persists, which tells me it's either the lamp itself, or the way it was installed.
What do you think this is?
Photos of the lamp and the base:
enter image description here enter image description here enter image description here enter image description here
  • Can you post close-up shots of the lamp base with no bulb installed? This sounds like something's arcing inside... Commented Sep 24, 2016 at 13:27
  • Is the lamp on a dimmer?
    – Comintern
    Commented Sep 24, 2016 at 14:27
  • @Comintern Nope, no dimmer there.
    – lesssugar
    Commented Sep 25, 2016 at 11:11
  • @ThreePhaseEel I updated the post. Hope these photos are any good. Also, sorry, I was AFK.
    – lesssugar
  • Were either of those two other bulbs you tried an incandescent?... Try a different manufacturer's CFL.
    – Mazura
    Commented Oct 27, 2016 at 21:34
Does this lamp have a florescent ballast inside? This type of lighting will make that hum you are describing. If so, you can replace the ballast.
  • It's fairly apparent that the lamp has a standard bulb socket, and that a CFL is installed.
    Commented Oct 27, 2016 at 21:28
  • @Jonathan727 Why are you replying to me? It's not my question.
    Commented Oct 28, 2016 at 13:14
