As you can see on photos there are some burn marks. Really hot moka pot dropped down and I want remove them.What would you suggest me?
P.s.: I am actually not sure if flooring is pvc P.s:.I thought about grinding it with sandpaper and then fill it with something
    The first step is to figure out for sure what the floor is made of. Do you have any extra boxes of the material in the garage or attic? Looks like maybe linoleum tile...
    – mmathis
    Sep 20, 2016 at 16:23
  • I actually dont have an idea what the floor is made of but I have added another picture to my first message
    – allstar
    Sep 21, 2016 at 13:06
For the most part, you don't. These kinds of plastic flooring materials are simply not very durable, especially to heat. But maybe you can cover it up with paint or something, after sanding or grinding down the black stain.
  • I just would like to cover it however after sanding I guess there will be a hole with the deepnes 0.3 maybe 0.5 cm. So I thought about filling it with silicon then paint it with a similar color to flooring
    – allstar
    Sep 21, 2016 at 13:08
