I have concrete floor that has sunk about 1 1/2 IN from the center from the sides walls some pare of it has vinyl on it . Do I have to remove the vinyl before ussing compound.How can I level this and what compound should I use . Thanks
Regards
Ali
  • Hello, and welcome to Stack Exchange. It's a bit tough to understand what you're asking; you might want to edit your question to make it clearer. Sep 20, 2016 at 11:32
I'd remove the vinyl. The leveling compound should go on top of the bare concrete.
But before you do anything: check if the foundations are okay. If the floor isn't properly supported, the added weight from the leveling compound will make the floor subside faster.
