Can I connect my dishwasher drain directly to the waste disposal or do I have to connect the dishwasher drain to an air gap first?
Are you using the dishwasher port on a garbage disposer? That effectively is an air gap itself. The dishwasher then dumps into the disposer chamber and drains from there. – Tyson Sep 18 '16 at 0:15
Add a comment
If you connect above the U bend or P trap this will work. If the connection is below the U bend or P trap sewer gasses can enter the home these can be both unhealthy and explosive.
