This fiba tape stuff protrudes from my drywall. Are you supposed to sand it? I don't see the use of it for patching a hole if it's thicker than my texture. Looks bad.
http://www.lowes.com/pd/FibaTape-300-ft-Self-Adhesive-Joint-Tape/50183377?cm_mmc=SCE_PLA--Paint--WallRepair-_-50183377:FibaTape&CAWELAID=&kpid=50183377&CAGPSPN=pla&store_code=102
Or is this user error?
Thanks
You need a putty knife, and some joint compound to apply over the top of it; the mesh provides some structure over the hole, you build it up just a little higher than the undamaged area, and feather it smooth; when you sand it, you will be sanding the compound, not the mesh. If you are careful applying the compound, very little sanding should be needed.
