Problem
I have a ceiling fan that is running slowly. I suspect it's the capacitor at fault. I don't see any bulging, but the fan spins for all three settings of the pull chain switch.
Diagnosis
I have two more identical fans in other rooms in my house. I swapped out the switch housing assembly (the part with the switches, wires, and capacitor) from one of those, and the fan runs fine.
Questions
Is there a name for the block capacitor packages that have multiple capacitors inside of them? Some term that I can google?
I have been able to find block capacitors with three 5μF250v capacitors inside ... can I use this, or do I need to replace the 5μF300v capacitor with another 5μF300v capacitor ? I thought the fan is running at 120V, where is the 300V coming from? I don't see any kind of transformer.
If not, where should I look to find a suitable replacements capacitor? I contacted the manufacturer (Hunter), but they were no help. The only offered me a discount on the purchase of a new fan.
