I'm about to install an Over The Air (OTA) antenna as the first phase of cutting the cord.
I understand the antenna and coax cable need to be grounded. I can purchase and drive a grounding rod where the coax enters the house and connect the coax and mast ground lines to that grounding rod no problem.
The thing that's preventing me from going forward with the job is that I'm not sure how to then bond the antenna grounding rod to my home electric ground. I've read that this should be done with a 6 AWG copper wire, but I was planning on routing the coax into my house where my satellite coax currently enters, which is on a different side of the house from my water pipe and my breaker box.
Of course the satellite installer didn't ground the dish or the coax cable, so I can't reuse any of that.
Is it okay to have the jumper from antenna ground to home electric ground just laying on the dirt outside the house? My concern is that I don't want to bring a (probably) unsheathed conductor, whose entire purpose is to carry lightning, into my house. I had read something online about not having the bonding wire within some distance of the soil, but that didn't reference any NEC codes.
I just want to do this right so I don't set my house on fire. Lightning running down a 6 gauge wire routed through my walls seems exactly like how that would happen, but I'm not sure how else to attach the two grounds.
