250.53(D)(1) Continuity. Continuity of the grounding path or the bonding connection to interior piping shall not rely on water meters or filtering devices and similar equipment.
250.68(C) Grounding Electrode Connections. Grounding electrode conductors and bonding jumpers shall be permitted to be connected at the following locations and used to extend the connection to an electrode(s): [ROP 5–138]
(1) Interior metal water piping located not more than 1.52 m (5 ft) from the point of entrance to the building shall be permitted to be used as a conductor to interconnect electrodes that are part of the grounding electrode system.
With regards to the two above quotes from the NEC 2014, how does the existence of a jumper across the water meter affect the continuity of the grounding electrode system? In particular, my grounding electrode conductor is terminated approximately four and a half feet from the point of entrance of the interior metal water piping to the building (satisfying the five foot requirement), but the water meter is approximately two feet from the point of entrance. I understand that the issue with the water meter is in the event that it needs to be serviced, a path of continuity might be compromised. In my case, this path would still exist due to the existence of a jumper, but does it matter that the jumper is a separate wire from the main grounding electrode conductor?
In other words, do I need to run an entirely new grounding electrode conductor?
