I have some blinds that have metal side pieces made from (I believe) aluminum. The sides are runners that the blinds and the handle slide up and down in.
The problem is that these are about 5mm too long for the height of the window so I need to cut them down. I know nothing about DIY and have few tools :P
What tools do I need to do this? I assume some kind of hand saw might do? Or is there a power tool? I don't mind spending a little money on a tool that I can use in future for other projects. But specifically what do I need to cut through thin metal reasonable neatly.
Any advice welcome, I want to learn (Even if it's you should get someone in to do it!)
