I'm about to start a stair refinishing project. The stairs are 100 years old, red oak. My plan is to stain treads and paint risers..
Question - what is the best sander to use on the treads? Is an orbital (palm) sander good enough? I want to minimize any swirl marks. Any advice on grit level would be appreciated as well.
Thanks!
  • Depends on at what point you'll be doing the sanding. Sanding down an existing finish is likely going to be a huge pain. If that was your plan, you might consider using a stripping agent and scraping it off first, before touching with a sander.
    – Steve
    Sep 13, 2016 at 14:00
  • When I do get to a sander, would you suggest a orbital sander or finishing sander?
    – Parv
    Sep 13, 2016 at 14:06
Since you plan on staining the stairs over, you definitely want to use gentle methods to remove the existing finish, without damaging the wood beneath it. Unfortunately, you did not include a picture or description of what the stairs look like now, so my advice may not completely accurate for your situation.
You wouldn't want to try sanding off old varnish, or several layers old paint. All that will do is create a lot of dust, and you will burn through many different pieces of sand paper or sanding discs without making much progress. Personally, I would try using a chemical stripper to remove the bulk of original finish. When you use a chemical stripper, you will want to have plenty of ventilation to get rid of the fumes, even when using one which claims to be safe. You can also use a heat gun, and a dull putty knife to scrape it down. If you plan to scrape, do not use a sharp blade such as a chisel, window scraper, or a floor scraper. These tools are far too sharp, and will damage the wood.
Once you are down to nearly bare wood after stripping, then you can start the sanding process. Since this is a hard wood, the surface of the wood shouldn't require much sanding. I would start with around 80 grit paper, and knock down all the high spots, and remove the bulk of the old finish that is left over. Try to avoid sanding directly into the wood with lower grits of paper if at all possible. From there, you will want to sand with progressively finer sand papers until you reach 300-400 grit. If you are using the correct grit of paper, you shouldn't have to pass over an area more than a couple of times to sand it down properly.
After the old finish is sanded off, you will want to use progressively finer sand papers to remove the marks left over from the rougher ones. There is an order of progression in the grits that needs to be followed to get the best results. If you start at 80 grit, the order goes as follows: 80, 100, 120, 150, 180, 220, 240, 280, 320, 360, 400. It is permissible to skip a grit or 2 in the middle if you do not have it available. You wouldn't want to skip more than a more than a couple in a row such as going from a 120 to a 240. All that would do is burn up sheets of paper, and leave a poor finish. On a painted surface, you can stop at a lower grit such as 220 or 240. 400 grit is great for stained surfaces. It has a finish that is almost as smooth as glass. You could go from 400, 500, and 600 grit if you choose. Anything higher than that is not recommended, or necessary. There are higher grits up to 1000, and even higher, but they are usually reserved for fine furniture, and when sanding between finishes. Besides, you wouldn't want the stairs too be too smooth because people would slip on the finish. I would probably go no higher than 400.
As far as sanders are concerned, I would use a trusty old sheet palm sander. They are easy to control, and they aren't very aggressive with the sanding, so you can really fine tune it. They are also square or rectangular, so you could easily sand into most of the tight corners. When using this kind of sander, you should wear padded gloves since the vibration from it can lead to fatigue. The sander won't be able to get into every crevice. I would recommend using a sanding block, or just a sheet of paper to get into the tight areas. Orbital sanders, especially those that are not the random type, are pretty aggressive, and it is very easy to sand too deeply into the wood. They are also circular, so they will not get into any of the corners. A random orbital sander could be used to do the bulk of the sanding, and the sheet sander can finish it up if you have both.
A random-orbit sander has proven to be one of the most versatile tools I've used, having put hundreds of hours on them for projects of many types. Obviously they have limitations, but with a range of paper grit on hand they're invaluable. Note that this is not the same as a conventional "orbital" sander, which can be a dangerous and damaging instrument in the wrong hands. RO sanders are very forgiving to the novice.
You may also need a detail sander to get into the corners. These have pointed plates of various shapes that allow very close access, but they're much slower due to their more limited range of motion.
Finally, your hands. Sometimes the right manufactured tool simply doesn't exist, and a folded up sheet on your highly-evolved digits is the best approach.
  • No matter what sander you use, you'll probably want to start w/ a reasonably coarse grit and finish with a fine grit to get a supersmooth surface :-) Sep 13, 2016 at 15:53
  • Yep. I'd go 80-100 through 180 or 220.
    Sep 13, 2016 at 16:01
  • Sharp scrapers are the way to go but that isn't for a novice. As a mention, I would start with a 40 or 60 grit to remove the finish, a finer grit will readily clog when the surface gets hot.. Then go to the finer grits as you suggest.
    – Jack
    Sep 13, 2016 at 17:51
  • I'd only go that coarse if there's heavy paint or varnish to remove. Otherwise it's going to make more work with the recovery.
    Sep 13, 2016 at 18:13
floors are very different from furniture. 400 grit is way to fine for stairs, especially stained ones. I own a floor refinishing company and do a set of stairs every couple of weeks. we typically start with 60 grit paper to remove old finish. if there is paint to be removed start with 36. palm Sanders are nonsense. lowes and depot sell an orbital sander by dewalt. it is a 5" 8 hole? sander built on a drill with a dust collection port for 90 dollars. 60, 80 and 100 or 120 for anything darker than a provincial stain. use a multi tool with a triangle or "mouse" sanding head with the same papers. for the final sand, use the multi tool to sand with the grain. this will hide any swirl marks. you must then water pop the treads. wait for it to dry and apply the stain with a foam brush, rags or a stain applicator. wipe off each tread with a clean rag before moving on to the next.
