I installed a new vanity recently as I am wrapping up a bathroom remodel but when I went to install the p-trap I realized that the p-trap is 1 1/4 inches and the drain pipe at the wall is 2 inches. I looked online for more info and to see what kind of adapters I may need but I couldn't seem to find anything. Are there adapters I can get for such a large diameter change? Are there online resources that I just didn't find? Thanks!
  • A common scenario is the reducer Ed posted, then a short run of pipe, then a threaded end fitting, all cemented in place. Everything upstream of that uses compression fittings.
    Sep 13, 2016 at 15:02
A 2" to 1-1/4" reducer like this should work. This was the first one I found but they are out there. Home stores should stock them also.
If you can't find it, you could put a 2x1 1/2 bushing on there and a small piece of 1 1/2 to your adapter.
