Is mounting the PCT-MA2-P2 behind an interior wall a code violation?
The power (15VDC 250mA) to the PCT-MA2-P2 is input via RG6 coax cable with F type connector. The media room on the second floor has coax from the master bedroom closet on the first floor. I want to feed the antenna from the attic directly to the input of the PCT-MA2-P2 in the wall of the media room below, and then connect the coax cable from the master bedroom closet to an output port of the PCT-MA2-P2 to carry the antenna signal to the master bedroom closet. There it will connect to the input of a similar device with eight output ports connected to RG6 cables distributing the antenna signal to the other rooms of the house.
The PCT-MA2-P2 will be accessible through the hole where the wall plate is mounted. The wall plate will have two F type ports: one to feed power to the PCT-MA2-P2 and one connected to the other output of the PCT-MA2-P2 to bring the antenna signal to the media room TV.
For aesthetics I'd prefer only adding another cable to the view as opposed to three cables and the PCT-MA2-P2. The second picture does not show the PCT-MA2-P2 device in the wall nor the second output cable connected to it which is going to the central distribution point. I will probably adhere a piece of furring strip to the inside of the back wall with Liquid Nails® and screw the device to it so it can be seen through the hole. This is Texas, USA.
