In my home one distribution board indicate supply but when I connect any appliance to board the board indicator is off and appliance does not work. Other distribution boards are working.
  • What country are you in?
    – DoxyLover
    Sep 9, 2016 at 7:07
  • India 50 Hz frequency.
    – Manoj
    Sep 9, 2016 at 7:40
You probably have a wire break, a corroded or loose terminal, broken receptacle, or something somewhere. All of those situations can create a high-resistance on the circuit. That resistance can be low enough that a low current device (such as an indicator light) can still work and a multimeter will measure the correct voltage. But a high current device won't work.
See Why does my GFCI circuit breaker trip with any small load, even after replacing the breaker?
