I'm looking at attaching shelves to a brick wall using single-track metal strips with adjustable brackets. The metal strips will be 78 inches long and I'm planning on using pine shelves 47 x 12 x 3/4 inch. There will be 5 shelves in total. How much weight do you reckon I could put on each shelf? And what length screw would be the minimum I would need?
4Can't calculate the load without knowing the screw type/size. Screws are rated by their shear and pull-out strengths in different types of materials -- pretty easy to select screws once you know the load. – user4268 Nov 13 '11 at 0:04
If your brick is solid and does not seem to be crumbly (like in +100 year old house) then I would always suggest and even my self use and Anchor bolt - In some countries called a robolt - These are on of the best load and pull rated bolts. And I always try to use these bolts because you can never be sure about who will put what on a shelf. Using these bolts if installed correctly(not difficult) are rock solid.
- The downside to using these bolts is that you need to drill very deep into the brick. 8-10cm for a small bolt.
- The upside though is that it passed the monkey test1.
All you have to do is:
- drill the correct diameter holes into to the wall as straight as possible in the correctly marked locations.
- Remove the bolts mechanism, feed the threaded rod through the rail and replace the bolt mechanism on the other side of the rail.
- Repeat at key location on the rail.
- Place against wall and insert all bolts as evenly as possible.
- They sould slide in easily but you apply more pressure to get it in there.
- Tighten each bolt until you feel it getting harder turn the wrench.
- You want to get it tight enough where you feel enough pressure that will make you change your standing stance. That should do it.
- By this point it should pretty rock solid!
And because this is for your home and not a building site you would finish it off with a bolt "nut" cover. This will give you some extra points with the wife for paying attention to the finer details. You can get various shapes, colours and finishes. Or just paint over them.
Using anchor bolts makes you only have to worry about the bearing load of the brackets and shelves you use. But it is obvious the shelf max load should not exceed the anchors load capacity to be safe.
I have seen shelves that collapsed because the bracket could not hold the weight but these bolts stayed put!
Disclaimer: Just a bit of humour but entirely factual.
1Monkey Test
It is a test that is taken out on shelves , hooks or other newly installed equipment that will be used to hang things off. The test is simple. Hang on the object and wiggle like a monkey. If it does not rip/pull out / bend or create damage to the area around it. It is monkey proof and guarantees to carry ridiculous load. Tested in South Africa in camping sites near nature reserves on outside fixtures
There will be no practical limit. Shop for screws first: each will have a rating for load. The more the better obviously, the thicker the better especially in softer brick. Most of your load will be shear, some will be pullout load. You'll want to figure out how deep the brick is: there is little cost to going most of the way through each brick.
The masonry screws have a special thread and require a hole drilled with the recommended carbide masonry bit for proper fit and thread bite. As brick is quite solid, as long as the brackets don't have too much standoff between the head and the wall, they can carry just about all the load as shear which as Bryce points out, means the load carrying capacity is limited by size (shear strength) and number. – Fiasco Labs Sep 9 '12 at 16:02
