Some time ago, I bought a second-hand table saw. The original owner had extended the table with a section where he mounted a router. The holes are in the pattern of a Group C router and I recently bought a Porter-Cable 7518 which should fit. The holes line up but the screws holding the sub-base on the router base are 5/16"-18 and have a head about a 1/2" across. The countersink holes in the table are much smaller. Are 5/16" machine screws available with smaller heads? It doesn't seem that a reducer (a 5/16"-18 outside thread and something smaller inside) would work well here, if such a thing is even available. I could get smaller machine screws which would fit inside the threads in the base and then put a nut below but that would certainly make mounting and unmounting a chore. I could get a larger countersink bit and make the holes fit the larger heads but that seems hard to get right. Any thoughts?
Router table Closeup of hole and screw
    Are the holes in the table possibly counterbored for cap-head screws rather than countersunk for flathead screws? Or just increase the size of the countersink... – Ecnerwal Sep 8 '16 at 3:03
  • No, the holes in the router table are conical pits, not cylinders. – Chris Nelson Sep 8 '16 at 13:59
    A larger diameter counter sink bit and or possibly one with a shallow taper. You do want the heads to be flush or slightly below the table top. not really that difficult. counter sink just a little at a time checking to see if the heads will sit flush. This can be done with a hand drill. – Ed Beal Sep 8 '16 at 15:16
