What kind of gloves should I wear during electrical work?
I need to know which glove material is most suitable for this kind of work, as I wish to purchase the proper gloves.
Sign up to join this communityWhat kind of gloves should I wear during electrical work?
Depends on the voltage you're working with.
If you're working in a residential setting, simply turn off the power and wear any type of glove you find comfortable (including none).
If working in an industrial setting, where turning the power off is not an option. You'll have to choose a glove system based on the voltage you'll be working with. A glove system should always consist of an appropriate insulating glove, and a protective leather glove. A glove liner is an optional part of the system, and can be worn depending on how dainty your hands are.
ASTM D120-14a divides gloves into the following classes:
WARNING: Always properly test your gloves before each use. Visual inspection and air testing is the most common method. If you're using these gloves, you've hopefully been trained how to care for and test them. If not, you probably shouldn't be doing anything that requires you to use them.
If you are not working with live circuits or high-voltage capacitors -- and you shouldn't be, if at all possible -- gloves are unnecessary
For residential work, gloves are unnecessary and perhaps counterproductive. Best practice would be to:
Get a bulk pack of cheap mechanics gloves. Take a few pair and cut the fingers off until they look like these expensive ones.
(source)
I cut all the fingers off, but be sure they still cover your second knuckle. That's about all they're for; to protect your knuckles against the sharp edges of J-boxes, and having a cover on your palm while you payout wire.
Note, these only alleviate abrasions and in no way will they protect you from electrical hazards.
You only need one glove to keep from having a fatal shock to your heart from one hand to the other unless you are standing in water on concrete or ground with conductive shoes. Any glove that protects against contact would help, but an cloth lined rubber glove could save you. However, if you ask this question, you are probably not qualified to do electrical work.
