having big problems trying to drill through a reinforced lintel to hang some brackets, i presume the concrete lintel has steel in but using a hss drill bit fails - which are the best type of drill bits to use, technique and which ones are the best.
thanks
    Before drilling into a critical load-bearing part of your house, perhaps you could look for some other method to attach the brackets. Sep 6, 2016 at 20:20
I had similar problem when putting up curtain brackets and hit a steel lintel. I was recommended 135deg split point cobalt and a good metal cutting paste. I must say I am well impressed with results.
I was also advised :
  1. Drill slow
  2. Use light pressure
  3. Use cutting paste
  4. Stop every 10 seconds to give the bit a chance to cool down
You need a carbide drill bit like this. High speed steel will dull quickly. A hammer drill would also help but I have cut small holes with a regular drill motor in the past really hard on the drill bumping it constantly to simulate the hammer action.
  • That is perfect to get through the concrete, but if he's really hitting steel then HSS will be better at that point.
    – Mark
    Feb 13, 2017 at 23:50
    I wouldn't use a "hammer anything" on a reinforced concrete lintel. That lintel is designed with a certain amount of bonding around that reinforcing and the hammer action could crack/loosen the concrete from the rebar. I'm sure it's over designed, but why push it.
    – Lee Sam
    Mar 20, 2017 at 4:31
