I have an old zinsco panel(I know...) in my garage. It's a 100 amp service panel not a sub panel. The panel is grounded to a ground rod and bonded to pipes. There is also bonding strap from the panel to the bar in the panel. Should that strip stay connected to the neutral/ground bar in the panel? Both neutrals and grounds share the same bar in this panel. Thanks
1I trust you when you say that 'you know' about the Zinsco, but how would you feel if your house burned because you ignored a known safety hazard? – Aloysius Defenestrate Sep 5 '16 at 15:27
Add a comment
