I'm going to cut into the double drywall on the sidewall as you walk down our basement stairs and build some shoe storage out of plywood to attach to the wall, so it's like a cutout into the wall.
I'm not sure about what to do where the plywood box meets the drywall wall. I could have either be the exposed edge. All I can think of is to have the plywood be the exposed edge and then cover with moulding.
Other ideas appreciated.
