I cannot seem to find the right bracket to use as a hold down on the tree side for a treehouse knee brace beam. I need to find one that can bolted to the tree and hold two 2x8's. It looks just like this but I can't find it anywhere.
Also, how do you attach the knee braces to the corners of the platform? There seems to be various ways of doing that. Thanks!
Not too hard -- the page I suspect you got that photo calls it a "hold-down bracket," and that exact part appears to be available here, fastenersplus.com
the bracket
I'll take my finder's fee in chocolate :-)
  • WOW, I have looked up and down for this! Where do I send the chocolate!!! I assume 2.5 inches wide will hold two 2x8's? THANK YOU!!!
    – chiltonjh
    Commented Aug 30, 2016 at 19:27
  • 2-1/2" won't be great for 2-2x8, as you'd have to remove 1/2" of material (thus weakening the support). Better would be 2 brackets with slices of 1/2" ply padding out the 2x material. Commented Aug 31, 2016 at 2:37
  • @chiltonjh If this works out for you, please mark the answer as accepted. Thanks! Commented Aug 31, 2016 at 11:04
