I am trying to get rabbet of sizable width 2" into 3/4" plywood. I was looking at rabbet bits and the depth (3/8") I need is not and issue but getting the width will be a challenge. The largest diameter I have seen is 1-1/4", and I know I would need to make multiple passes at like 1/4" at a time to get a clean cut as well.
How many bit would I need to accomplish this cut? What would be the sequence of steps to perform it?
Thanks in advance.
