27
I need to temporarily remove the baseboards in a couple rooms. I am interested in some suggestions for removing the baseboards without damaging them so they can later be reinstalled. Suggestions may include
  • Helpful tools
  • Pitfalls
  • Removal techniques
  • Reinstallation techniques
  • Systems for keeping track of where the pieces go
  • In Addition to the pry-bar approach, a home center or hardware store may have plastic wedges -- or you can try using wooden shims -- which apply outward pressure as you tap phem in from the side. I've sometimes found these easier to control than flat bars.
    – keshlam
    Jan 9, 2017 at 22:37
4 Answers 4
31
Pretty easy DIY job. All you'll need is: a hammer, old metal putty knife, utility knife, small pry bar, pliers, and a pencil. For reinstallation, a finish nail gun really makes the job go fast, and a nail set is also useful.
The typical procedure:
  1. Cut away any caulk on the top edge and corners.
  2. Check any inside corners to see if they are coped rather than mitered. If they are coped, you have to remove the coped side first.
  3. Use an old putty knife to pry back slightly between the top edge and the wall. Focus any prying near the studs or where ever you find nails, pulling where there isn't any nail too far will risk cracking the trim.
  4. In the crack, use a small pry bar so that all the force is applied to the back of the trim, and not the top edge. Work you way down, one end to the other. To protect the wall, pry against the putty knife rather than directly against the wall itself.
  5. Pull any nails in the trim through the back with a pair of large pliers rather than hammering them back out the face where you'd damage the wood and paint.
  6. Number the back side of the trim and the bottom of the wall where the numbers will be covered up upon reinstallation.
  7. For reinstalling, a nail gun works best with finish nails. One nail per stud and two at the ends is usually enough for basic trim. Use a nail set to sink any nails slightly below the face of the trim. If a nail starts to bend, pull it with the pliers, using the putty knife to protect the trim. Do not bend the nail over and hammer it in sideways.
  8. Paint any trim before it goes on the wall, use a small bit of spackle or wood putty on the nail holes, caulk the top edge and joints, and all that's left is a bit of touch-up paint.
Pitfalls:
  1. Prying too hard and too far away from a nail, causing the trim to crack.
  2. Applying force to the delicate top edge.
  3. Trying to pull the flat end out of a coped corner first, breaking off the delicate coping.
  4. Not cutting away any caulking, resulting in the paint and drywall pulling away with the trim.
  5. Trying to knock out any finish nails back through the face of the trim, causing lots of damage to the trim.
  6. Nailing in a groove or somewhere that you can't get a smooth spackle finish.
  7. Nailing so close to the edge that the trim splinters.
    End cutting pliers (nippers), work well for pulling nails out of the trim. Just don't squeeze too hard, or you'll cut the nail.
    – Tester101
    Nov 1, 2011 at 11:46
  • Really nice response. Nice tips: pry against putty knife, pull nails through back.
    – Mario
    Nov 1, 2011 at 14:52
16
I use a painters multi tool to pry loose baseboards. Its wider and thickeer than a putty knife. It also has a hard place on the end of the handle where its meant to be tapped with a hammer. I find it pretty handy. Painters multi tool
    In 25 years of home-ownership this has been the single most used (and maybe abused :) tool I have. Nov 2, 2011 at 0:17
  • Good point. I use my putty knife because it's already seen a lot of (ab)use and I like to get my painters tool in good condition. But given the choice of buying a new tool, this is good for hammering and prying, but it may be harder to use for protecting the wall from the pry bar.
    – BMitch
    Nov 2, 2011 at 1:19
  • We now have one of those for each floor. A slightly different version, which combines a screwdriver and removable bits in the handle...kind of a gimmick but better than not. Nov 2, 2011 at 19:47
  • I just bought one of these - without the screwdriver gimmick.
    – Mario
    Nov 7, 2011 at 17:19
I like these:
They're about $10, and are very useful for finicky "demolition" work where you want to preserve the materials.
I have a quality steel Japanese made version of this style that is much thinner and sharper on the leverage end (right).
The thin cross-section allows it to slide behind just about any molding without damaging the edges while the width of the blade spreads the force so it doesn't readily split the wood.
