Question: How do you get rid of hand prints on a pine table from under a treatment of colored danish oil?
Background I was varnishing a new unfinished pine table, and decided to use a fine sandpaper over the surface of the table. However while doing this I rested my hand on the table, and might have left some sweat / body oil on the table. This was not visible on the unfinished table, but soon as I started applying the stain/Danish oil I noticed a lot of my hand prints appear in a few spots on the table.
I could sand down the entire finish and restart, but short of that, is there any other way that I can mask / get rid of those hand prints?
Thanks and Regards, Basil Dsouza
You might try applying another coat of the stain/oil, applying it using superfine (0000) steel wool. Rub it in with the grain. This may help break up the residual film you left and let the stain penetrate a bit.
If it doesn't work, you'll be no worse off if you have to sand and refinish.
