I have an outlet that is dead by the refrigerator. Can I use an extension cord temporarily and what would be the minimum? It is a small apartment sized refrigerator.
  • How long a run to the next good outlet? – bib Aug 22 '16 at 23:44
  • What is the amperage of the refrigerator? – bib Aug 22 '16 at 23:55
  • I would buy the shortest appliance rated cord that will reach the nearest outlet. No don't use that 50 or 100 foot orange 16/3 cord from the garage. – Tyson Aug 23 '16 at 1:38
  • There should be a tag on the back of the fridge or possibly on its cord. This tag should specify its electrical requirements: some combination of amps, volts, and watts. Could you edit your question to include that information? – user4302 Aug 23 '16 at 14:41
Wire gauge tables for 16AWG list the maximum carrying current from 4 to 10 amps continuous; for 18AWG, 2 to 5 amps (for under 50-ft lengths, at least). I think it's unlikely that your fridge draws more than 2 amps under any conditions ( if you have a tag on the unit which lists watts, just divide watts by 120 (voltage) to get amps), so any extension cord you have will be fine. However, if the fridge has a 3-prong plug, be sure to use a matching 3-wire extension cord for grounding safety.
|improve this answer|||||
