Is the wire gauge the same for solid and stranded wire? I need to check the wire gauge of some stranded wire. Can I use standard wire strippers to check the gauge of stranded wire?
1 Answer
I found the size difference is ~5% larger with stranded than solid depending on the strand count. The sizes are far enough apart that the strippers if in good shape are a great tool for measuring.
