My bathroom, like most, has a GFI outlet. It trips ALL the time even thought nothing is plugged into any outlet. I know people say they go "bad" all the time but it seems silly how mine is set up. It will trip when I turn on the lights every month or so. When it does, the entire bathroom loses power instead of just that plug.
This set up seems to be the same for my office and all of my outside outlets. Both 20 amp circuits have a single GFI plug on a regular breaker and will kill power to the entire circuit. Is it safe to replace these plugs with a standard plug and use a GFI breaker on this circuit to prevent random trips? Is my set up odd or am I just crazy thinking the GFI outlet should only kill power to that outlet?
