When I was installing a quartz countertop, i had it upside down so I could mount the sink to it. When I flipped it over, there was a small scratch in it (the quartz was brand new). I assume there was a screw or something protruding from the cabinet underneath it. I have seen you can use super glue technique to mask the scratch, but I was hoping there would be something else that would work better.
Do you have any adhesive/sealant left from the install you could fill it with?
Mine came with color matched adhesive for the back splash pieces.
  • Unfortunately I am used a different material for the back splashes. The quartz I purchased came with no adhesive. The polymer compound I used on the underside would certainly not look great on top. Thanks for the advice though. Commented Aug 14, 2016 at 12:57
