I need a new washing machine and am leaning towards getting a stackable front loader (soon to be family of 6; it's just more efficient water/energy-wise), however, I also plan to cloth diaper my baby and know front loaders suck for washing diapers. I have a small apartment sized washer/dryer that I could use for the diapers but can't afford the new washer AND getting my laundry room plumbed with a second water supply. Is it possible to install some kind of valve that would allow me to switch between one laundry pair and the other? I realize I wouldn't be able to run them both at the same time (or would I...?) If I put two washer/dryers in my laundry room I wouldn't have room to just disconnect/reconnect the supplies, but I could probably get a hand back there to manipulate a valve...
Let's assume for now draining is not an issue...
  • You don't need to switch the water supply between machines. You can have them both connected and turned on at the same time. - They will interfere with each other only if you run both at the same time, and even then all that will happen is that they may both take a little longer to fill. Aug 9 '16 at 1:49
You could use a hose wye with shut-offs on both hot and cold. Make sure you buy a heavy duty brass one with ball valves. You can run both washers simultaneously as they fill until a sensor or float says the water level has risen to the set-point. It will just take a bit longer for them to fill if you run them at the same time.
    Just to be clear, you can leave all four of the ball valves open all the time. You need close them only when removing one of the washers. Aug 9 '16 at 1:53
