I'm replacing the drain pipes under my bathroom sink and having trouble removing the final section behind the escutcheon that connect to the wall fitting. I have a metal pipe extension pushed into a brass nipple fitting at the wall. The extension is trapped in the brass nipple via a washer that is internal to the brass nipple so I cannot pull it out without removing the brass nipple. The nipple has a hex nut but it's inset in the wall behind the tiles. I cannot turn it without removing tiles and causing wall damage. What to do? Photo links: https://i.sstatic.net/1th3h.jpg https://i.imgur.com/KDQ1PRD.jpg
  • Post your pic on imgur.com, then add the link/filepath in a comment to your question. One of us will post it to your question. When you have a bit more cred, you will be able to ad pictures directly to your post via imgur. Aug 5, 2016 at 21:14
    That is an unconventional assembly! Was there a nut screwed to those threads or was it just like that? Aug 5, 2016 at 21:56
  • Yes, there's a nut. I've included a photo of it here: i.imgur.com/QM0NDw1.jpg
    – user58375
    Aug 6, 2016 at 6:02
  • Have you tried twisting and pulling with a fair amount of force? That type of connection is usually a slip-joint fitting and can be pulled directly apart. The presence of the brass ring is pecuiliar, however; usually a rubber slip-joint washer would be found there. Aug 7, 2016 at 17:24
Cut the extension pipe off close with a hacksaw.
Then use a regular socket on the brass nut.
You could always cut into the wall just enough to do your work and then put a larger cover around the pipe to hide your mess. I'd find the cover first before cutting the wall so that you know for sure how much you can cut.
