There is a crack in a wall that I would like to fill with some removable insulation.
It must be removable, as such it should just be a temporary solution.
I know of rockwool and glasswool, but don't know which is best, or if there exist other types.
Which should I get and stump the crack with?
  • 8
    What sort of wall (material, interior/exterior)? Why are you trying to stuff it with insulation instead of repairing the crack? How big is the crack? Are you trying to insulate for heat, sound or visual? A picture of the crack may help
    – gregmac
    Oct 22 '11 at 19:07
  • Additionally, what caused the crack? How long is "temporary"?
    – Hemm
    Oct 24 '11 at 0:01
  • there really isn't a best insulation for crack repair.
    – DA01
    Oct 24 '11 at 1:25
    Blown-in insulation is technically removable if you have a shopvac! :)
    – Doresoom
    Nov 2 '11 at 19:44
You can use Backer Rod to fill in the crack if it is not too wide. Backer rod is an easy to compress rope-like celled foam and should be easy to remove at a later date. It is mainly used to fill deep cracks before caulking to give support to the caulk.
Backer rod comes in a variety of diameters and should be able to be found at your local building supply store.
