Okay so I have a 2 story house about 30 feet high and was wondering if this set up will work?
http://www.homedepot.com/p/Husky-20-Gal-175-psi-Quiet-Portable-Air-Compressor-C201H/206189626
http://www.homedepot.com/p/Bostitch-21-Degree-Industrial-Round-Head-Framing-Nailer-F21PL/100465406
I have quiet a lot of shingles to replace and would like for the power tool to run continuously. I'm just curious if it will work since the air compressor doesn't meet the SCFM requirement for the power tool i want to use. The air hose I want to use will be a 3-8-in-x-50-ft-F5-Male-x-Male-Fittings-Hose.
Will this work? If not can anyone please recommend the air compressor and hose i will need to run this power tool continuously.
