I've bought a data patch panel in order to cleanup my home network wiring (which was a mess). Before wiring the patch panel I didn't read about the two wiring options: 568A and 568B.
I've wired the patch panel as indicated (panel is 568A). I've installed one cat5e outlet in order to test if it was working properly.
I've used a basic network cable tester to see if everything was ok and it wasn't successful.
After reading more on the subject, I realized that my patch panel is wired 568A and the outlet is wired 568B. So my two options would be to 1. Re-wire the outlet to 568A; or 2. Re-wire the patch panel to 568B
What is the best option ? Is there another option ?
