I have a wooden fence door with a metal latch. As shown in the below picture, something happened recently that caused the metal latch piece (and some of the attached wood) to separate from the fence door.
I want to fix this because the separation makes latching the door difficult. What is the best way to repair this? Might applying wood glue, along with using a large clamp or vice to push the separating wood back into position, repair this?
I would,
  • unscrew the latch and remove it,
  • apply wood glue under the broken piece,
  • clamp it and let it dry for an hour or two
  • drill some deep pilot holes through 95% of the thickness of the whole gate
  • reattach the latch with longer screws .
I would consider using bolts instead, with washers to spread the load on the far side.
  • Might also move the whole latch up or down an inch when re-installing it (both parts.)
    Aug 3 '16 at 15:47
    I would skip directly to step 5: longer screws. Glue has no place here. If longer screws don't do it, move on to bolts.
    – Mazura
    Aug 3 '16 at 18:10
