Are there any tricks to drain a tank-style water heater?
Or is it as simple as attaching a hose to the small drain pipe and then opening the valve?
Some web references have said you need to open up another valve somewhere so that air can enter in order to allow it to drain, whereas other web references make no mention of this.
