I have heard Roxul is safe and non-combustible, I need to wrap something around the vertical hot water tank piping leading up to the attic. This pipe can be seen in the basement ceiling and there is space around this pipe I want to use two layers of Roxul material to wrap around.
Could this become a fire hazard somehow by trapping the heat and causing nearby wood to ignite?
