Recently replaced dimmable LED bulbs with non-dimmable bulbs in a light fixture/ceiling fan that uses a dimmer switch.
In the last week, it started randomly turning off and on. Now it won't turn on at all, even when I put the old bulbs back in the fixture.
Is it possible that I could have damaged the fixture or the dimmer by doing this? I have never used dimmer switches in the past and did not personally install the light fixture so I wasn't aware that there was a difference.
If so, how would I go about troubleshooting the damage?
